aj290 said:My 528I is currently in the shop as we speak. have had problems with the Trans also.
They are replacing the speed sensor on the trans as the speedo was not working and it seems to be erratic when tested.
I see in this thread others that this had solved the problem. I also have a problem with the ABS computer. Can this affect the transmission operation?
aj290 said:I just got the car back, they replaced the speed sensor part number 24151219659. Speedo worked for a bit then stopped, still starting in 3rd gear. We get the following codes:
130 signal ,CAN ACS1
217 signal , CAN EGS( OBDIIo600;EUIII
o600)
Chek Engine , Trans,ABS,ASC Lights on.
I am thinking of sending in the ABS control module to be rebuilt as this was the first set of lights that came on a while back. BMW wanted 900 bucks to fix it. Auto Ecu will do it for 289.00. CAn I drive the car without this module??
Also, is it true that you cannot clear all the codes in the computer memory? I was told by my trans guy that in some cases you need to take it back to the dealer to have the codes totally cleared. Thoughts?
From what I am reading in this thread this may be the root of my problems.
Please let me know your thoughts asap.
I have a similar problem. What fixed yours?
This happened to me on my 528 - last night (Aug 1, 2007) I had the same problem as you did last year - I am in Vero Beach and it rained very hard - think I may have slipped the tires, now the ABS lite is on and the car is in limp mode- not shifting well- what happened with yours? How did you fix it?
Any thing would be helpful!
Chuck Correll
[email protected]
Need some help. I have a 1999 528 i sport. Four lights come on the dash: Check engine, ASC ( the console button is not depressed), ABS, and a yellow star off the the right of the dash near the seatbelt light ( I have to look this light up in the owners manual). Now I checked the codes came up with 2 codes the first code is p0600 ( serial comm Link Malfunction) and P1747 ( transmission). What the car is doing is it starts up fine sometimes and goes then all the lights start to come on and the trans shifts into 3 or 4 or 5 gear on take off from a standstill. Anyone know what will give you a Serial comm link malfunction code? Or a transmission code? Is the car running in "safe Mode" if so why would it shift into high gear and stay there? I would really appreciate any help anyone could give. I am not able to find any good sites on problems and remedies with codes. Bringing my car to the dealer is not an option.
