Im new here but reading reviews for some time. I have a similar problem others have discussed. My nav screen goes black then has lines and dots and then will come on for a while and stop. I have reset my nav computer several times and it helps but now it is getting worse. Now I notice my radio is shutting off after about 2 minutes and 40 sec. I push power on off and it will run again for about the same time. This is with my nav computer hooked up or out. I have the nav computer out right now and the radio still functions and then shuts off after the time period.
I have checked my battery and it is working fine with normal charge. so this is eliminated. can the nav computer being out still have an effect on this. What else could I look at for trouble shooting. If my nav computer is not causing the screen to go haywire then something else is the common issue for both problems.
Anyone have some more ideas to look at.
Thanks James
Thanks James
