1 - 4 of 4 Posts
I love my 2001 BMW. When I hit a pothole at low speed the front wheels go into a "high speed wobble". this is what we call it in my motorcycle days. It handles fine otherwise.
I am concerned this may cause an accident in the future. Any thoughts?
Nick Brown:):):confused::)
bushings
my 97 528i did that as well had shaking when braking.
i replaced the thrust arm bushings and it took about 90% of the shake away
Hmmm... easiest thing to do is put your front end up on jack stands and get under your car and start looking at your front suspension... anything cracked or does anything have excessive play? Thrust arms, as mentioned above, could be a culprit.
With wheels off the ground, grip your tires at 12 oclock and 6 clock - can you move the tire back and forth? Same thing for 3 and 9 oclock. Check your lug nuts too while you're at it, make sure they're torqued down firmly.
Is there any wobble when you brake as well?
1 - 4 of 4 Posts
