1 - 2 of 2 Posts
I own a 2001 740 IL love the car but wiper motor ploblems are driving me crazy.First wipers would not park replaced wiper motor and they worked for two weeks then stopped as if fuse had blown. checked relay and found water in bottom of relay compartment.cleaned out drain and found 2 broken wires at relay. repaired wires and wiper motor will come on if I ground out one of the relay coil pins.I still think there may be fuse issue I cannot find fuse 55 which is listed on fuse box cover but has no spot inside.Any advice?
Certifiable BMW Whackjob!
Look in the trunk above the battery. If I read the list correctly you should also check fuses 3 & 28.
And just for reference, there are even more fuses under the passenger seat.
Welcome to the 'fest!
1 - 2 of 2 Posts
