1 - 1 of 1 Posts
Hello everyone...:)
I recently had some issues with my 01 750iL...:-(
Car started smoking(bluish smoke) and developed a rough idle plus tons of ECU codes...:-(..Engine cylinder misfire etc..
I did some research and found that the OSV valve might be the issue..
So I took the intake manifold off and discovered oil in the intake ..it was pouring out.... I also removed all the cooling components (radiator, waterpump etc...)
Question...I am thinking of changing the head gasket while I have everything apart..Is this a big job(special tools etc) ..
I am on the fence over this since the somke was probably related to the oil in the intake..?
Any one do a headgasket on a V12?
1 - 1 of 1 Posts
