Hi all,
Newbie here. I was changing my oil today and noticed an issue with the OEM oil filter that I got from BMW (part number 11 42 7 512 300). So the old filter that was put in was a Purolator (part number L25247). The OEM filter is probably 1/8 to 1/4 inch bigger in diameter and about 1/2 inch taller. In screwing the new OEM filter in, I noticed that the added height seemed to make it much harder to screw in. I finally did manage to screw it in all the way, keeping the torque below 18 ft-lb, but I'm pretty sure that the filter's pretty twisted up and compressed in there.
Now looking at a few parts websites, both part numbers appear to be correct.
I followed Hayaku's thorough DIY guide for changing the oil on the X5. (Very helpful, thanks much)
http://www.xoutpost.com/articles/x5/engine-transmission/9479-oil-change-diy-bmw-x5-3-0i.html
The photos of the inside of the oil filter compartment seems slightly different from mine. Mine appears to have a flat 'ring plate' on the bottom that probably acts as the holder for the filter whereas Hayaku's X5 did not. There's a similar plate on the oil filter compartment cap.
Anyone have experience with this? Thanks much in advance!
Chewy
Chewy
