I need a little advice here. I have a 2002 330i and experiencing a rhythmic thumping noise and slight vibration coming from right front wheel at speeds between 5 and 25 MPH. The frequency of the thumping is proportional to the speed of the car so it appears to be a dynamic component of the drive train. It doesn’t matter if I am braking, accelerating, clutch in or out. Above 25 MPH the noise and vibrations smooth out. It sounds as if the wheel is not balanced and there is a flat spot on the tire but at speeds above 25 mph it is smooth. The wheels are balanced (at least for highway speeds). Could the wheel be out of balance for speeds between 5-25 mph yet be balanced at highway speeds? Or is there something else in the driving train or suspension of the right front wheel going bad? I have ruled out the wheel bearing since it is fine at highway speeds. Also ruled out the brake rotor. What else is there? Anyone else experience this?
