1 - 1 of 1 Posts
PART 1 - Descriptions and Parts list:
This particular vehicle has just over 150,000 miles on the odometer, and although no slip can be noted from the clutch, the SAC has about 2 inches of clutch uptake remaining. This results in a clutch that is difficult to modulate, and makes for unpleasant driving when in stop-and-go traffic for example.
Because the Dual mass flywheel employed by BMW on this particular vehicle often requires replacement along with the clutch, a complete refresh of both clutch and flywheel is in order.
Along with these two major mechanical components, a shifter bushing refresh will also be performed, and all major seals and bearings will be inspected and replaced as necessary.
Once the clutch has been removed from the vehicle, a test for play on the flywheel will reveal if it too needs to be replaced. This play will be evident when moving the flywheel forwards and backwards in relation to its outer diameter. If the flywheel begins to display an apparent wobble, it will need to be replaced. The mating surface between clutch and flywheel must also be inspected, in order to guarantee correct fitment when only replacing the clutch.
The complete list of parts to be replaced is as follows:
Shift Bushing Refresh:
25 11 7 571 899 - 2x - Shift Rod Circlip at Shift Rod Joint and Shift Lever
25 11 7 519 669 - 1x - Shift Lever Support Arm Bushing
25 11 1 221 849 - 1x - Locking Pin for Shift Lever Support Arm Bushing
25 11 1 222 015 - 1x - Shifter Arm Plastic Bushing
25 11 7 580 281 - 1x - Shift Rod Joint
25 11 1 469 397 - 1x - Shift Tower Bushing for Shift Lever Pivot
23 41 1 466 134 - 1x - Dowel Pin for Shift Rod Joint
25 11 1 220 439 - 4x - Yellow plastic washer/bushing/shim for shift selector rod
Clutch Refresh:
07 11 9 906 045 - 6x - Pressure Plate Bolt
11 21 1 720 310 - 1x - Pilot Bearing
21 51 1 223 328 - 1x - Pivot Pin for Clutch Fork Lever
21 52 6 785 966 - 1x - Clutch Slave Cylinder
18 10 7 502 346 - 2x - Exhaust Manifold Gasket
21 51 7 570 284 - 1x - Spring clip for clutch assembly
23 12 1 228 328 - 1x - Input Shaft Seal
07 12 9 900 047 - 6x - Lock Nut, Hex Head - M12 x 1.5, as needed
18 30 1 737 774 - 4x - Copper Lock Nut, 10mm Exhaust Flange
23 12 1 282 394 - 1x - Selector Rod Seal
21 21 7 512 474 - 1x - Flywheel, 240mm, Dual-Mass
22 31 6 799 331 - 2x - Transmission Mount
11 14 1 438 274 - 1x - Crankshaft seal kit
23 12 1 222 771 - 1x - Output Shaft Seal
26 11 1 227 410 - 1x - Flex Disc (Guibo)
23 11 7 510 016 - 1x - Clutch Release Bearing (Guide Sleeve)
26 12 7 501 257 - 1x - Center Support Bearing
21 21 7 523 620 - 1x - Clutch Kit
83 22 0 309 031 - 2x - Redline MTL Gear Oil (1 Quart)
all BMW parts are purchased from bmw greensboro nc @ Eurobahn Motorsports http://www.eurobahnm.com
A picture of all components is attached to this post for reference.
When all is done, the vehicle should display correct clutch modulation, along with restoring a "like new" shift-feel of the transmission.
Stay tuned for a documented review of the installation and results of this service.
1 - 1 of 1 Posts
