1 - 3 of 3 Posts
No A/C... I have changed the coolant temp sensor, A/C pressure sensor. While charging the system, my low side pressure continues to climb near 120 psi, (and the high side matches); however the clutch never engages to cycle the coolant. I have checked for voltage to the compressor: none. Aux fan does not run. I have checked the continuity across the clutch to ground: OK. My A/C pressure switch (new) shows 5 volts on the reference voltage, ground is good, signal wire shows 1.3 volts. Any Suggestions?
120 equilibrium sounds about right.
AC won't run If the aux fan isn't working.
Make sure the fan turns a bit when you first start the car (it's a test it does to confirm the fan is there)
Nuclear engineer
02/2012 X5 35d M57Y CPO 98K miles NOKIAN WR G3 12K miles
" ready state.The IHKA transmits a speed increase request to the ECM.
Depending on the temperature and the nominal-value setting, the IHKA sends a cooling
power request to the ECM If theECM is ready and in a position to provide
a torque of > 20 Nm, the ECM issues a release for a load connection of up to 30
Nm. This release is also monitored by the junction box. The IHKA issues a command to
the junction box to couple the connection. The junction box returns the coupling status to
the ECM."
1 - 3 of 3 Posts
