1 - 5 of 5 Posts
Hi Guys,
I bought a 2003 bmw x5 auto three months ago but now it is not changing all the gears.its onlyy changing up to the 3rd gear even if i engage manual drive. what could be the problem?
Thanks in advance.
Moses
Bimmerfest Founder
Welcome to Bimmerfest! I've moved your question to our X5 forum, you will get more help in here. Have you tried getting the transmission fault codes pulled? That would be a good place to start.
Tim
Probably it was serviced according to BMW recommendation - means never, since it is filled "for life"?
If so, it is probably reaching its life..
You can try to flush it 2- 3 times (single flush replaces only small portion of fluid - the majority of it is in in torque converter), replace filter and couple seals and hope that this will help...but also be ready mentaly and financialy for new/rebuilt transmission
I've just replaced by box with a rebuilt one as mine shredded inside! Cost me £800 for the box nearly 200 for oil and filter then £150 to get a family friend to fit it at his garage, try getting it serviced
1 - 5 of 5 Posts
