1 - 1 of 1 Posts
Hello! I have recently purchased Dension Gateway 500s BT with intention to fit it in my BMW E60 530i. The car is CD changer prepared, therefore it was meant to be a quick install with little coding. I installed everything, coded CD changer and BT telephone in. Bluetooth connectivity works fine with iDrive, including phone book, I can answer and dial and the reception icon works as well, CD changer also showed up, but all disks (CD1 - CD6) are grayed out. I have done a bit of research on the Internet, but cannot find the answer. I have tried coding $672 and +IPOD on CAS and LMA and CDC and MP3 aktiv in M-ASK. No luck... The vehicle is '04 plate, all modules on the car have the earliest firmware versions (2003 and 2004), there is not MP3 playback from disk reader on centre console, there is a factory fitted business sat nav (M-ASK).
Have you got any ideas? Or could you suggest a garage that would be able to help and get it work?
Thank you!
1 - 1 of 1 Posts
