1 - 2 of 2 Posts
Hello I'm chuck. I have a 2005 745 li that that seems to be blowing out white smoke and a little water from the tail pipe. The tail pipe also has a rattle noise after you start it up. All of this started after I had my care towed home. First it was the rattle after the towining company took it off the truck imeadiately. Next when I took it to the towining shop to let them check the rattle the said they put a wrap to hold the pipe it helped with the noise a little until I took it home. Then I noticed the smoke. Prior to these two thing the pipe did not rattle neither did the car smoke. Are there any easy fixes.
Bimmerfest Founder
Welcome to Bimmerfest! I've moved your question to our 7 Series forum. My guess is you've got a valve stem seal issue but it wouldn't have happened just because of a tow.
Tim
1 - 2 of 2 Posts
