Guys
I have been dealing with no crank no start issues over last 2 weeks. No crank, No start, but all the electronics in the car work. The car was just redone, engine overhauled and transmission serviced. Since getting it back I have had this gremlin. I just replaced a 2 week old starter again, had a new key made, replaced the IVM module, new 30G relay in the truck, added new grounds to post under the hood, cleaned up the grounds to DME and right engine mount, and with all that I still have this issue.
The battery is less than 2 years old and it puts out over 12.5 volts with car sitting and the charging system shows me 14.2 volts when the car is running. I just got back from the having the battery tested at AutoZone (failed even though it reads 12.7 volts), at the O'Reilly's (failed even though it puts out 12.65 volts) and it passed at the Advanced Auto Parts (reads good battery on their tester).
I do not have a means of checking for codes (INPA etc) and my regular code reader shows no codes.
I can however start the car even when it gives the no crank situation. I just keep cycling the key on and off and eventually the car will start.
