1 - 5 of 5 Posts
Help! I just replaced the CCV system on my '05 325Ci. I did this because of a consistent SES light that came on every 250 miles or so, and a slight oil leak that suddenly got worse. Disassembly found the dipstick return tube had fractured in two.
During reassembly, I thought everything went well, took my time to make sure I was doing everything right (as per the 50s Kid on YouTube). Return hose from oil separator back to manifold was really tough to connect on both ends, but I thought I finally did it. All other hoses seem to be tight. All wiring is hooked up correctly.
The problem- when I started the car afterwards, it ran very rough, searching for idle. Heard a random "clack" sound (not continuous, just a random noise) from the manifold. Then it threw like 10 codes. A 306 Random misfire code, was stored, along with specific misfire codes for all six cylinders pending. P0171 & 174 codes were also pending. Short-term fuel trims that were 15-18% before the replacement were at 24%. Cleared the codes & restarted engine. It was a bit smoother, codes didn't come back, but the random "clack" noise was still there.
What did I miss? Any help is appreciated!
Keeping it surreal
Did you replace (or at least thoroughly clean out) the dipstick tube with a new one ? This is an essential part of the repair process.
Have you examined/repaired/replaced the DISA valve ?
Discussion Starter #3
I looked over the DISA valve- nothing obvious wrong, but what should I look for?
I did pull the dipstick tube, sprayed WD40 down the oil return pipe and watched it drip out the end. That would seem to indicate the tube is clear.
The best way to clean the dipstick tube is used brake cleaner.
Those 2 codes are classic indications of vacuum leaks. The best way to find vacuum leaks is to have the intake smoke tested. Find a reputable indie shop that specializes in bimmers at www.bimrs.org.
Re-check wiring connectors. The first time I did a CCV, it ran fine but wouldn't idle. I had left one connector unplugged, coming from near the front of the big junction box as I recall. Hope it's that simple for U.
1 - 5 of 5 Posts
