So two years ago, I had kept getting repairs and doing multiple drive cycles. Finally it ended up being a secondary mass airflow relay. And then it passed smog. Now it***8217;s time for smog again, engine light is on. Same code***8230; Secondary mass airflow sensor. But on the professional code reader it has several misfires codes. We found a big vacuum leak and plugged it , yay! Well the engine light came back on. I***8217;ve replaced the secondary mass airflow sensor three times, it wasn***8217;t bad. I***8217;ve also had the intake airflow valve that looks like a small aluminum flying saucer cleaned. Still engine light came back on after reset. I have a nice mechanic who tries to help me. He had an X5 for seven years. But he works at a shop and can***8217;t give me discounts. And I can***8217;t afford to keep having things tested. I just received some parts I ordered, the air injection valve mentioned above, that looks like a small flying saucer on the engine block, A fuel filter, and spark plugs, even though I had the spark plugs replaced two years ago. My friend the mechanic said he would put the fuel filter on for me free. But I also have the other things I have to do and hopefully something helps. What is your experience? Someone must***8217;ve had the same issues with 2005 X5 3.0. Please please please, help me
