2006 325i stereo wiring
20K views 8 replies 4 participants last post by  gbalthrop
#1 ·
Hello,
I just got an e90 2006 325i and was trying to put the OEM stereo back in its spot. I think j might have one problem with wiring harness. Do you guys know if the power cable (red) should go with rest of the wires? If so where in the attachable head. If possible, can anybody attach a picture of their wires leading in the radio?
#3 ·
The following link is to the TIS Online Manual for your 2006 E90 325i:
https://www.newtis.info/tisv2/a/en/...udio-video-telephone-navigation-most-ring/headunit/radio-voltage-supply/sLN4dAx
As I read the diagram, the Red/Green (RT/GN) power wire attaches to pin 15 of the connector which is numbered X13812. If you click on the blue X13812 hyperlink, and then select Connector View (-2009/08), you will see the pin numbering for the connector. Most BMW Connectors have TINY pin numbers on the outboard edges of the pin holes or connector, visible with bright light & some magnification.
George
#6 ·
Hello,
George
Hello George,
Pin 15 looks like it is filled but I have 2 other pins that are empty. I don't have any red wire going to that head of the harness
If you don't mind looking at the picture I attached and let me know your thoughts
