For the alternator/bsd codes, ISTA diagnostics says to unplug each bsd component one at a time and scan it until you then other codes go away- leaving you with one bsd fault. That will give you the faulty bsd component. I had a cheap brand alternator cause my bsd issue. Even following those instructions I couldn’t pinpoint my issue, but it turned out to be the alt. If you have an aftermarket alternator - that’s probably the issue there. Oil sensor, water pump, alternator, and IBS are all share the bsd line
