...2006 BMW 330XI..One morning he started the car and oil began to seep out of the oil cap (the car was about 1 quart low on oil). He immediately had it towed to a shop where they checked for faults and sure enough there was a misfire in cylinder 5 and 6. He was told that until the valve cover was removed, there would be no way to know if the car needed a new engine...Brand new ignition coils, oil and spark plugs.
QUESTIONS:
1. What performance issues were experienced BEFORE that morning?
1a. WHAT caused him to open the bonnet and check the oil filler cap after starting the car that morining?
2. Did the SES light ever come on BEFORE that morning (a misfire lights the SES, at least during the misfire episode and sets a code in DME memory WITH mileage when set saved in Freeze Frame Data)?
3. Were the new coils, plugs and oil change done BEFORE that morning?
4. Why were they done & by whom; were they based upon performance or oil leak issues?
5. What diagnostics were done to determine there was a misfire, cylinders 5 & 6?
5a. Did the "shop" test crankcase pressure in any way -- even as simply as opening the oil (filler) cap with the engine running? I presume you are talking about the FILLER Cap, and NOT the OFH (Oil Filter Housing) Cover that is removed to change the filter?
6. If someone read codes P0305 & P0306, did that someone bother to read Freeze Frame Data to determine the MILEAGE when the codes were set?
7. Has anyone bothered to simply remove the coil cover and check to see if there is oil in the plug wells on those two cylinders?
We can ONLY GUESS without more specific info, but it is possible that:
a) There is a problem with the external oil separator/PCV system that is causing positive pressure in the crankcase (and valve cover area).
b) This positive pressure then causes oil to leak at gaskets (particularly the gaskets around the plug wells), and possibly even at the oil filler cap on top of the Valve Cover.
c) The oil in the plug wells affects the coil plug boots and ultimately causes a misfire.
Unless the "shop" the vehicle was towed to was given or obtained different information from what you have stated here, I certainly would NOT rely on any diagnosis or recommendation made by that "shop." NEW ENGINE because of an oil leak? New engine because of P0305 & P0306? Remove Valve Cover to diagnose a "positive crankcase pressure issue"??? Did the "shop" happen to share their opinion on the CAUSE of oil being expelled from the top of the Valve Cover at the filler cap?
George
