1 - 1 of 1 Posts
I have my X5 acting weird after battery went out, the ventilaton flaps are not working, in the sense that they wont move, it doesn't matter what setting I put in the controler, the flaps are just blowing to the defroster, I took the central vents out and moved the central flaps by hand (I know, not the best course of action), and got them to blow air to the front, again tested the footwell and defroster, no change at all (the recirculation and temperature flaps work just fine), the after I turned the car off, wait a few minutes, then turned it on, the central flaps go back up to the position before being moved by hand, in the scanner (Maxisys pro) all live data from the ac controller is accurate, if I change it to footwell, the scanner shows the footwell, after Messing several days with it, I already recoded the module, and no change, any ideas?
1 - 1 of 1 Posts
