2A84 | DME: Inlet VANOS 2 | n62_tue2 | Engine electronics | View |
Fault Code Description |
Fault Code Conditions |
Fault Time Condition |
Inlet VANOS 2 |
Service Plan |
'A' Camshaft Position - Timing Over-Retarded (Bank 2) |
Fault Impact |
none KL_15 = true Bank 2 intake controller monitor (max. control deviation (differential spec./actual data) is 5°KW) VANOS may not be at travel limit, that is Vsa2_sprs<120°KW. |
Warnings |
Service Notes |
Test sequence (after each step stop to determine whether fault is present): 1. If the corresponding camshaft fault has been logged, start by checking the camshaft sensor 2. Check oil level 3. Check VANOS valve for contamination 4. Replace solenoid valve 5. Replace VANOS adjustment mechanism |
2A91 | DME: Exhaust camshaft 2, tooth offset to crankshaft | n62_tue2 | Engine electronics | View |
Service Plan |
Crankshaft Position - Camshaft Position Correlation (Bank 2 Sensor B) |
Fault Impact |
none KL_15 = true One-Tooth-Off detection on bank 2 exhaust (if OK: Vsa2_adp delta for last driving cycle < 16°KW (Dnwoto_mn/mn)) VANOS must be against travel stop, thus Vsa2_sprs=120°KW. |
Warnings |
Service Notes |
Test sequence (after each step stop to determine whether fault is present): 1. If entry for corresponding camshaft sensor is present, start by checking camshaft sensor 2. Check solenoid valve for contamination / inspect terminals 3. Cross-change solenoid valves 4. Check/correct camshaft and valve timing and/or alignment 5. Replace VANOS servo unit 6. Install new timing chain assembly (complete) |
I believe the vehicle had a very old oil, did oil change and old oil was very dirty ****
If you have a single bad coil that's all you need for your symptoms.
Get the replacement in, clear the codes, run some injector cleaner through (I usually use Lucas at one bottle per ten gallons).
Report back after. It's pointless to try to fix anything when you have a bad coil. The car will kick on limp mode with one bad coil. You did the right test to see if the error will follow a coil swap so now you replace and go from there.
The over/advance cam error can be an error carried forward from from crank sensor
