1 - 6 of 6 Posts
I checked the secret menu
but cant tell if it has the latest software that might correct the sluggishness at lower speeds
this is what I get
Champ build 827
HMI Release 6.2.19.1
BEXEL Version BZ_DO_HW_4.0_SW
CDMech Version
CDM-M8 v45H
anyone know what the heck that means
anyone else solve this?
Discussion Starter · #3 ·
this is what I get
Champ build 827
CDMech Version
CDM-M8 v45H
BMW Called me today to tell me there is a Recall on a Fuel pump and will look at reprogramming the X5 at the same time
to check your programming idrive
hold down idrive 10 seconds realease
turn right 4 clicks
turn left 4 clicks
turn right 1 click
left 1 click
right 1 click
push down idrive and release
Get Coded
Ah, okay. I've seen the 3-click one, but not the 4-click one. I'll try that later today to see what versions I have.
Thanks for the info.
"2008 e70 sluggish at lower speeds"
Do you have the 3.0? If yes, that's the reason why.
Get Coded
I tried the sequence you stated, but it doesn't work. I know of the 3 click instead of 4 click way.
I have the full navi idrive so my menu looks different than yours. I'll see if I can find the same info you found.
1 - 6 of 6 Posts
