1 - 2 of 2 Posts
I have searched online and learned about the schrader valve on the fuel rail. My question is how much fuel is going to come out when i press the valve?
Will a towel or rag be enough to catch it all or is there another method? I am trying to repair a hair line crack in the top of my fuel sender on the left rear, but i can stop the fuel from seeping through because of the pressure.
Any help be would much appreciated. Thanks.
You can try unscrewing the gas cap to relieve some of the pressure or pull the fuel pump fuse crank the car 3 times and there shouldn't be anything left in the rail. Good luck!
1 - 2 of 2 Posts
