1 - 4 of 4 Posts
The CAS fuzes are both in the front fuze box; inside the glove box. They are F7 - 30Amp and F15 - 5Amp. Can't easily determine if the diversity antenna(s) receive power directly from the CAS though.
Good luck,
Fred
Discussion Starter · #3 ·
Good luck,
Fred
Hi Fred,
Thanks for your response. But my car's fuse diagram (found in the trunk of my car) shows that fuses 7 and 15 are both for 'seatbelts'. Are you sure about those?
Thanks,
Brian
Did you look at the owners manual? I referenced the E60 Bentley manual for the location. You should have those fuzes in the glove box. There's a small panel to remove, at least in my 2007 that's what I have.
1 - 4 of 4 Posts
