So my wife drives a 328i and it needed a new battery. So I took the battery out to get tested and to buy a new one instead of taking it to a dealership. I closed the trunk not thinking and now I can't open it. I've tried hooking up jumper cables to the terminal under the hood and nothing. Bmw is wanting to charge us $800 to break out a rear light to open it and replace the light which is freaking stupid. Im over this car cause it's had a lot of issues. Can any one please help... There has to be a way into the trunk!!!
Easiest way out is to get a charge into the battery so you can open the trunk...unless the rear seats fold down, in which case you can go in that way (hint, hint...)
If the battery is a lead-acid battery, get a good quality battery charger, connect it to the terminals under the hood, start it and walk away for 12 hours to get a charge in the battery.
If the battery is a gel type, you need a standard battery as a buffer. (Check the directions for charging Optima batteries online for specifics.) Here's what to do:
- Park a vehicle with a standard lead/acid battery next to the BMW. (Or pull a standard battery from another car)
- Connect jumper cables between the lead/acid battery and the charging terminals on the BMW.
- Now connect the battery charger to the lead/acid battery, and walk away for about 12 hours.
The lead-acid battery serves as a buffer and will allow the gel battery to take a slow charge.
If you don't own a good charger, get one. Every garage needs one.
PS: I did procedure #2 last weekend when I accidentally ran the Optima battery in my 280ZX flat. That's the way to charge a battery of that type when they get too low.
