Hi everyone,
I’m the owner of a newly acquired 535i with 111k miles that was well cared for in its previous ownership. The car is covered in Space Grey Metallic paint (A52), black Dakota leather interior, and sport automatic transmission.
Though I’m extremely excited to own this LCI E60, I’m not new to BMW, nor is this my first E60. I’ve had the pleasure of owning several E30s, E39s, and an early model M54 E60.
The plan for this build is to make this high-mileage N54 extremely reliable for daily driving duties while retaining it’s OEM nature by using quality parts and tasteful modifications. Moderate performance mods to follow: stage 1+ tune and some bolt ons.
The car itself is well equipped with nearly every option available from the factory except for night vision, lane keep assist, and heated steering.
The car has the factory m-sport option only available on 2010 models (suspension, aero, m dead pedal, anthracite headliner, steering wheel, and m door sills), comfort access, premium package, heads up display, comfort seats, lighting package, logic 7 audio, PDC, sport auto transmission, style M135 wheels, CIC iDrive with aux/usb input, dynamic drive, heated seats.
Interior pics to come later
The car has extensive maintenance history with records going back since 1,000 miles. The car’s HPFP was replaced 4 times (3x under warranty). Recent service history completed during previous ownership include:
Oil filter housing gaskets @ 111K
Walnut blast @ 107K
Thermostat/WP @ 99K
Index 12 injectors @ 97K
Spark plugs @ 97K (coils weren’t done)
High pressure fuel pump @ 97K
Valve cover and gasket @ 83K
Known flaws at purchase include:
For addressing current issues and preventative maintenance, here is what I have planned:
Planned modifications and upgrades:
Exterior
Interior
Performance (tentative)
Undecided/considering
Let me know if there is anything I missed re: maintenance or have suggestions for mods/upgrades.
JP
Walnut blast @ 107K
Thermostat/WP @ 99K
- small chips on the passenger rear door
- front and rear windshield seals are rotting
- thrust arm bushings are shot
- brake and power steering fluid needs to be flushed
- aftermarket battery installed in May, wasn’t coded/registered
- new OE power steering reservoir and fluid
- new drive belt, pulleys, and tensioner
- upgraded PCV valve
- upgraded coolant inlet flange (aluminum)
- expansion tank replacement
- new engine air filter
- new cabin air filters
- upper and lower radiator hose replacement
- front and rear windshield seal replacement
- 6HP19 automatic transmission service (filter, pan, hardware, valve body sleeves, shift solenoids)
- note: will do plugs and coils once current coils fail, or before performance mods
- VANOS solenoids (should I leave these alone or replace as PM?)
Exterior
- 3M Ceramic IR tint 35 all around
- LUX H8 Angel Eyes
- OEM style trunk lid spoiler
- Paint-matched front bumper reflectors
- Rear-axle wheel spacers (15mm)
- Chrome/amber turn signal bulbs
- Style 135 wheel refurbishment w/ new tires (TBD)
Interior
- BimmerTech MMI prime CarPlay retrofit
- Integrated rear view camera/trunk handle
- Red start/stop engine button
- Wireless charger retrofit
- MHD Stage1+ OTS tune
- 1 step colder plugs (with new OEM coils)
- BMS dual cone intake
- BMS charge pipe
- Forge diverter valves
- 5” intercooler (TBD)
- Hamann style CF front-lip
- Some type of cat-back or axle back exhaust
- Style 166 or other OEM 19” wheels
JP
