1 - 6 of 6 Posts
Your owners manual has guidance on whether you can or cannot, did you check?
where da clutch at ?
BMW 128i Convertible E88 N52B Executive Package
Here you go:
Make sure that the ignition is switched on, ; otherwise, the low-beam headlamps, tail lamps, turn signal indicators and windshield wipers may be unavailable.
There is no power assist while the engine is off. Thus, braking and steering will require increased effort. Active steering is not active and it will be necessary to turn the steering wheel further.
Automatic transmission
Selector lever in position N.
Changing selector lever position.
and a towing distance of 90 miles/150 km; otherwise, the automatic transmission Do not exceed a towing speed of 45 mph/70 km/h and a towing distance of 90 miles/150 km; otherwise, the automatic transmission may be damaged.
1 - 6 of 6 Posts
