Trouble shooting so far:
1) Open oil filler cap to check if crank case pressure is causing a seal to squeal - Negative
2) Water on the belt - Positive result. The noise instantly went away.
A reminder, the belt and aforementioned pulleys are all brand new. The belt is the suggested Continental part# on FCP Euro. The sound did not change after swapping those parts in.
The only thing I can think of is a pulley misalignment. If that's true it's going to be hard to track down which item is bad because the belt is running really true on all the surfaces. This ChrisFix (min 2:00-3:00) video is almost identical to what I'm experiencing.
Has anyone encountered this and can give a good guess which item is likely worn out (alternator, power steering, A/C condenser)?
I was also thinking of thinking of trying belt dressing or aerospace 303 protectant for a simple long lasting fix.
