1 - 8 of 8 Posts
Yes, I bought this car at auction and replaced the battery. Starts and drives. I know nothing about BMW's....I have worked on many Hondas. Any idea where to start with all this? FYI...although they labeled it a flood vehicle, it is very clean in and out no obvious water damage anywhere.
Vehicle information BMW 2010_12 3'/328xi_N51 Status report VIN: WBAPK5C50Mileage:94,406 Diagnostics time: 2022/11/18 09:28 Path: Automatic selection > Diagnosis > Auto scan > System name DTC counts Status DME (Engine-Motor Electronics)
15 Fault EGS (Electronic Transmission Control GM6) 0 Pass VTG (Transfer Box)
3 Fault ABS-DSC (ABS-Dynamic Stability Control-Bosch) 6 Fault MRS (Airbag - Multiple Restraint System)
4 Fault KOMBI (Instrument Cluster)
1 Fault RDC (Tire Pressure Control) 0 Pass CAS (Car Access System)
5 Fault MOST (Media Oriented Systems Transport System Analysis)
0 Pass JBE2 (Junction Box Electronics 2)
1 Fault EKPS (Electric Fuel Pump Control)
0 Pass CBX-MEDIA (ComBox Multimedia)
2 Fault SDARS (Satellite Digital Audio Radio Service Satellite Tuner)
0 Pass FZD (Roof Function Center)
1 Fault RAD2-GW (Radio2-Gateway)
0 Pass RAD2-BO (Radio2-User Interface)
0 Pass SMFA (Driver Seat Module)
1 Fault FRM2 (Footwell Module 2)
4 Fault IHKA2 (Integrated Automatic Heating And A/C System 2)
1 Fault MaxiSys Vehicle Diagnostic Report www.autel.com
1. DME (Engine-Motor Electronics) —— ( 15 )
2. VTG (Transfer Box) —— ( 3 ) RLSS (Rain/Light Solar Sensor) 0 Pass
1.1. 2DEC Digital Motor Electronics (DME): power management, battery Absent
1.2. 2DED Digital Motor Electronics (DME): power management, closed-circuit current violation Absent
1.3. 2AA9 Digital Motor Electronics (DME): variable intake system, servomotor 2: activation present
1.4. CDA1 Message (steering wheel angle) error, receiver DME, transmitter DSC Absent
1.5. 2ACC Digital Motor Electronics (DME): DME master relay, shift delay Absent
1.6. CDAD Message (request for drivetrain wheel torque) error, receiver DME, transmitter DSC/LDM Absent
1.7. 2D16 Digital Motor Electronics (DME): Mass Air Flow (MAF) sensor signal Absent
1.8. 2D0F Digital Motor Electronics (DME): Mass Air Flow (MAF) sensor signal Absent
1.9. 2F08 Digital Motor Electronics (DME): Intake Air Temperature (IAT) sensor signal Absent
1.10. 2AAC Digital Motor Electronics (DME): variable intake system 2, self-diagnosis Absent
1.11. 2A82 Digital Motor Electronics (DME): VANOS (Variable Camshaft Timing) intake Absent
1.12. 2A7C Digital Motor Electronics (DME): VANOS (Variable Camshaft Timing), inlet, cold start Absent
1.13. 2D5A Digital Motor Electronics (DME): monitoring of engine torque limiting Absent
1.14. 2A87 Digital Motor Electronics (DME): exhaust VANOS (Variable Camshaft Timing), mechanism Absent
1.15. 2DEB Digital Motor Electronics (DME): power management, vehicle electrical system Absent
2.1. 53FC VTG (Transfer Box): supply of control unit: terminal 30 Absent
2.2. 53FD VTG (Transfer Box): supply of terminal 30g Absent MaxiSys Vehicle Diagnostic Report www.autel.com
3. ABS-DSC (ABS-Dynamic Stability Control-Bosch) —— ( 6 ) 4. MRS (Airbag - Multiple Restraint System) —— ( 4 ) 5. KOMBI (Instrument Cluster) —— ( 1 ) 6. CAS (Car Access System) —— ( 5 ) 2.3. CF5E Message (transmission data) error, receiver VTG, transmitter DSC/DKG/EGS/SMG Absent
3.1. 5F1C Dynamic Stability Control (DSC): brake disc briefly overtemperature Absent
3.2. 5DCF Dynamic Stability Control (DSC): control unit, undervoltage Absent
3.3. 6EC4 Dynamic Stability Control (DSC): LWS (Steering Angle Sensor) adjustment Absent
3.4. 6E82 Dynamic Stability Control (DSC): brake pad wear sensor, rear axle Absent
3.5. 6E4A Dynamic Stability Control (DSC): control unit, internal Absent
3.6. D359 Dynamic Stability Control (DSC): F-CAN no message (SZL) Absent
4.1. 9408 Multiple Restraint System (MRS): undervoltage during self-test Absent
4.2. 93D0 Multiple Restraint System (MRS): undervoltage Absent
4.3. 940A Multiple Restraint System (MRS): overvoltage during self-test Absent
4.4. 93FB No message (vehicle speed) from Dynamic Stability Control (DSC), receiver ACSM/MRS5, transmitter DSC Absent
5.1. 931D KOMBI (Instrument Cluster): overvoltage or undervoltage Absent
6.1. A0C1 Car Access System (CAS): output, terminal 50 Absent
6.2. A0B4 Car Access System (CAS): Engine start, starter operation Absent
6.3. A0B2 Car Access System (CAS): supply, terminal 30E/30L Absent
6.4. A0B1 Car Access System (CAS): input, selector lever position, implausible Absent
7. JBE2 (Junction Box Electronics 2) —— ( 1 )
8. CBX-MEDIA (ComBox Multimedia) —— ( 2 )
9. FZD (Roof Function Center) —— ( 1 )
10. SMFA (Driver Seat Module) —— ( 1 )
11. FRM2 (Footwell Module 2) —— ( 4 )
12. IHKA2 (Integrated Automatic Heating And A/C System 2) —— ( 1 ) 6.5. A0B5 Car Access System (CAS): fault, road speed signal Absent
7.1. A738 Junction Box Electronics (JBE): power supply interrupted Absent
8.1. A8FA Overvoltage Absent 8.2. A8F9 CBX-MEDIA: software reset Absent
9.1. DE8B FZD (Roof Function Center): LIN bus Rain/Light Solar Sensor (RLSS) Absent
10.1. 9E6F SMFA (Driver Seat Module): Switch block, seat adjustment, driver Absent
11.1. E59C No message (steering angle), receiver FRM, transmitter SZL/LWS/DSC Absent
11.2. 9CB5 FRM (Footwell Module): battery exhausted Absent
11.3. 9CC0 FRM (Footwell Module): communication with step motor controller on the right disrupted present
11.4. 9CC2 FRM (Footwell Module): right Stepper Motor Controller (SMC) signaling fault Absent
12.1. 9C6C IHKA (Integrated Automatic Heating and A/C System): supply, center console control panel, 12V Absent
See Training pdf's in attached References.
Start out with the electrical ones.
I have heard Autels are professional scanners but BMW diagnostics are better to have in most instances.
You only need a K/D can cable and a laptop . Then you download BMW Standard Tools and Ista D .
Ista D is a complete diagnostic solutions with a searchable data base and guided troubleshooting
containing essentially a shop manual and guided trouble shooting.
diagnostic manual ista/inpa https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwiY4bSH7rDXAhVO1WMKHe26CygQFggoMAA&url=http://www.carmod.ru/files/icom/istad_en.pdf&usg=AOvVaw07T_NaCfxo19teM9vkTF-C https://www.google.com/url?sa=t&rct=...7x8H3pN8h1fMuF Diagnostics with INPA. Part 1. | Bimmerprofs.com | BMW GROUP ISTA/P VERSION AND I-LEVEL OVERVIEW https://www.e90post.com/forums/attachment.php?attachmentid=1378544&d... What can ISTA-P actually do? INPA Tutorial Quickstart.pdf ISTA - User's Manual - Carmod.ru www.carmod.ru › files › icom › istad_en beginners guide to ista+ - Bimmerfest www.bimmerfest.com › guide-to-ista-pdf.786422 primary links Software - Help yourself BMW Doctor Dean Videos | Nathan's BMW Workshop ista problems E90 Down! E90 Down! Updating Failure ista problems
bmw boards and links E90/E91/E92/E93 (2006 - 2013) - Bimmerfest - BMW Forums AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software - E90Post - BMW 3-Series (E90 E92) Forum General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio - E90Post - BMW 3-Series (E90 E92) Forum ConnectedDrive / I-Drive / Navigation Related Discussion - E90Post - BMW 3-Series (E90 E92) Forum BMW Coding - E90Post - BMW 3-Series (E90 E92) Forum E90 / E92 / E93 3-series Technical Forums - E90Post - BMW 3-Series (E90 E92) Forum BMW Retrofits | CIC Navigation | NBT Navigation | Combox | ConnectedDrive | bimmerretrofit.com E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions - E90Post - BMW 3-Series (E90 E92) Forum
3/2007 328xi E91
INPA or ISTA are Free Downloads. INPA is "Factory-Level" and ISTA is "Dealer-Level" Diagnostic Software. ISTA also includes complete Shop Manual with Interactive Wiring Diagrams, Component Locations, Connector Views, Repair Operations, Torque & Fluid Specs, etc. You can install ISTA on ANY Windows computer. You don't need to be connected to vehicle (with "K+DCAN" Cable) to view documents. Just enter Last-7 Characters of VIN, so you can use DeskTop with NO Vehicle Connection.
INPA allows you to see "FehlerSpeicher" (Fault Memory) in ALL Modules and also "HistorySpeicher" or History Memory, in the DME (Engine Control Module), EGS (Automatic Transmission Module) and EKPS (Fuel Pump Module). HistorySpeicher continues to show last 10 DME Fault Codes (up to 3 occurrences of each) even after Fault Memory is CLEARED.
It would be helpful to know as much of the "Flood" history as possible, such as Mileage at time flooded, so you can separate apparent "water-caused" electrical issues/ Fault Codes from Codes that occurred at mileage BEFORE Flood. Evaluation of "Freeze Frame Data" or Fault Details would likely show a large number of codes at a mileage at, or approximately equal to current mileage (or mileage you began driving vehicle), and that data would be helpful in identifying flood-related issues.
It would also be helpful to know the maximum water level outside/inside the vehicle, although probably NOT available (?)
I would:
1) Get INPA (BMW Standard Tools), and a $30 to $50 K+DCAN Cable;
2) Connect INPA to vehicle and use "Functional Jobs" to view (a) "F2 Identification" which shows all functional Modules in the vehicle, and (b) "F4 Error Memory, ALL Modules" which shows the Hexadecimal Fault Code for ALL Faults in ALL Functional Modules. SAVE ScreenPrints of those screens.
3) Read History Memory in the three PowerTrain Modules: DME, EKPS, EGS and SAVE ScreenPrints.
Then, having saved the data, CLEAR fault codes in all modules. Run/Drive the vehicle in the neighborhood for 10 or 15 minutes, NOTING all Warning Lights or abnormal performance issues. Record that information. Repeat the Functional Jobs viewing/ SAVING of F2 & F4 Screens (Modules & Fault Codes). POST those screens here, and Forum Members can suggest "Triage".:geek:
With any luck, many of the faults occurred when Modules and/or Connectors were "submerged", and once dried-out, those faults will NOT recur. INPA tells you if a Fault condition is "currently present", or NOT. To the extent there is still water in components, or rusted/corroded connectors, we can address those as necessary.
George
Anti-Hack
Flood damaged E9x? Dragging it to the scrap yard is the best way to make it right. Hats off for the undertaking.
Salt water flood damage is even worse.
Buy socks on Amazon, not car parts.
Discussion Starter · #5 ·
Gentlemen THANK YOU for all the suggestions. I will circle back in the next few days with findings. FYI...it was not salt water. I have only driven the car a mile since purchase from auction.
Discussion Starter · #7 ·
I would:
George
Thank you for taking your time to respond. I will circle back with findings.
Former 325 e30, now 2011 328i e91 RWD
Ditto on the BMW standard tools route per George. I picked up a used Lenovo windows 7 laptop on Craigs list for $100. Then I picked up the $50 cable, and a preloaded hardrive with Standard tools and more off a super helpful seller on ebay for $50.00. That saved the downloads time. All works great for coding and diagnostic work. Best $200 purchase ever. Good luck!
1 - 8 of 8 Posts
