1 - 2 of 2 Posts
Hey
Anyone have a problem with the harmonic damper pulley on the crank shaft causing auxiliary belt damage?
I have been battling a screaming aux belt problem for weeks now. after replacing the tensioner and both idlers as well as the alternator and power steering pump (basically everything except the AC compressor my shop is now telling me that the harmonic damper mounted to the crank shaft is causing damage to the edge of the auxiliary belt.
Nuclear engineer
02/2012 X5 35d M57Y CPO 98K miles NOKIAN WR G3 12K miles
Hey ... my shop is now telling me that the harmonic damper mounted to the crank shaft ....
It is just a vibration reducer, not a harmonic damper. A harmonic damper has a flyweight of some sort.
1 - 2 of 2 Posts
