1 - 2 of 2 Posts
Hello folks! I hope you all are well!
So, this weekend I changed the oil on my F30 N20 this weekend, and for whatever reason, the oil measure option in iDrive is not working. I've let it run to get it to the proper temp. I've even driven it for an extended amount of time (had to drive an hour this morning). It will start measuring like normal, I'll hear it start to rev the engine slightly, but once it hits 17% it just quits. No messages of any type.
I drained a little over 5 qts from it, and put back the same amount, so I feel like I'm probably ok, but I'd like that reassurance of seeing it successfully measure the level. Any suggestions? I know there's a sensor, but I'm not sure where it is to check the connection(s)?
Thanks in advance!
1 - 2 of 2 Posts
