1 - 3 of 3 Posts
I had to had to replaced the headlight module because i was having a lot of condensation on my riverside headlight unit. I bought an aftermarket unit cause original one is too expensive. Now everything works but not the the side to side function or the vertical aim control function. Do I have to get any coding done or did I just get the wrong module? any suggestions or anybody has module an original module for sale?
thank you
Nuclear engineer
02/2012 X5 35d M57Y CPO 119K miles NOKIAN WR G3 30K miles
Condensation is caused by not running your high beams enough to heat up the headlight assembly and evaporate the moisture.
1 - 3 of 3 Posts
