Thanks. Glad to know it probably isn't my transfer case!
I do have a throttle remapped, which helps, and a Racechip, which also helps. But best is sport mode throttle or throttle reset. I wish I could code the throttle not to adapt!
Thanks. Glad to know it probably isn't my transfer case!I would notice very slight drops in power. They were just for a split second. It was only noticeable until moderate to high throttle such as merging onto the highway. I never would have connected the issue to the transfer case. It must be a known issue. The tech disconnected the transfer case and the issue went away.
The lag that you mention happens to me once in a while. I see someone else said to give it more gas or that you are in the wrong gear but that is not the case in my experience. I know what you are talking about.
One time was at a dead stop and put my foot right to the floor and almost nothing happened. It doesn't always happen but I have noticed it.
There is some lag build into the throttle. 3rd party companies sell kits to wire into the throttle to help with this issue.
Would you mind adding your info to the Transfer Cases Failure Database? I started a line for you.Welcome! I have a 2014 328d. I love it. 66,000 miles. I bought it new in late 2013.
I did need the transfer case replaced twice. I would get hesitation that was linked to the transfer case. No issues since the replacement about $20k ago. I think this was rare though.
1) The issue with the transfer cases has been the output flange teeth wearing down/stripping. This is a metal part, no plastic at all. Stories I've heard have been that the heat treatment wasn't done correctly or spec'd well. Most of the failures are 2014 cars. Very few 2015+ recorded on the forums/my database.I had a 2014 328dX, traded in April with 62K miles (for a 540dX). I loved the car, but had issues:
(1) Transfer case failure (word is they have some cheap plastic part prone to failure)
(2) Drive shaft bearing failure (kinda like a u joint, but only came as a whole unit).
(3) Failure of 3 of 4 of the fuel injectors (CEL diagnoses to this) at separate times - wonder if I got some crappy fuel, be careful of this ... there are some threads on what to look for.
Two of the injectors were covered, others were ouch. I was getting nervous running without warranty, but stuck with BMW diesel for my new ride because I like them so much. My sense is the core engine is solid (that timing chain issue was news to me) but the fuel and exhaust systems have some challenges (perhaps associated with meeting emissions?) but I***8217;m not sure.
I wish you many miles of trouble free cruise!
I tried on my iPhone - could read but not write to it. Will give it a shot tonight on my home computer.....
Can you add yourself to the transfer case failure database posted a few posts above too?
You'll probably want to have the transmission fluid/filter/pan replaced soon. ZF recommends this at 100k km (62k mi).Thanks to everyone for posting all the different issues to look for. I'm approaching 60k miles now
So just to make sure I've got you correct. It's not just the fluid and filter change? BMW actually recommends you change the transmission oil pan also?You'll probably want to have the transmission fluid/filter/pan replaced soon. ZF recommends this at 100k km (62k mi).
https://www.codemybimmer.ca/product/2017bmw-map-update/?v=7516fd43adaaRight now I'm in a desperate need for a Navigation update as the roads here are constantly under construction and the previous owner never updated (I'm on NEXT 2013-1). I'm considering getting the code from BMW because it seems to be the same pricing as the other guys. The threads on this topic are a bit all over and none seem to have links to where they got the maps. (I guess I'll keep plugging away).
Yeah, the pan has to be changed too. The filter is built in. There are lots of write ups and videos on how to do this.So just to make sure I've got you correct. It's not just the fluid and filter change? BMW actually recommends you change the transmission oil pan also?
I've seen that someone else did it through an indy for just under $600. But wow, I'm not looking forward to finding someone to do it.
Your diesel additive can be purchased at an auto parts store and done yourself. When I was looking for an Indie shop here in PHX, I just googled it, you can always read reviews.*Bump*
Now I'm ready for an oil change. The dealer wants $250 for the oil change and diesel fluid fill. Does anyone have a good independent mechanic in the South Orlando area they recommend?
(I don't like doing them myself even though I am perfectly happy to get dirty on other parts of the car)
If you want a reputable qualified service center that most of Fields BMWs "prior customers" (for a reason) go to for their service needs on their beloved Bimmer I recommend Magic Mechanic at 1432 Lee Rd, Orlando, FL 32804. (407) 629-2661. They are a full service center and work on most of the luxury brands including Bentleys. My 2014 BMW 328d goes to them every since the manufacturer warranty ended. They are likely to most qualified and honest place for Bimmers. And for the DEF like others have said - dont pay anyone for that job. If you can pull a bottle you can do your own DEF refills for a fraction of the price anyone will charge you. Here is what I did. You do need the special fill bottle for the input filler tank. I bought one liter of DEF off Amazon. Look up you tube to see how it works. When that bottle is empty go to Walmart and buy a gallon of DEF fluid (less than $20). It is the same stuff the dealership issues EXACT same ingredients and same stuff. Then that liter bottle you still have. Unscrew the top (yes they want tell you those are refillable) and pour the Walmart stuff into the same liter bottle and repeat until your DEF tank is full. My tank used about half a gallon the first time I did a refill so every refill should cost you about $10 going forward. Oil changes however I leave to the professionals. Cheers!*Bump*
High coolant useage has been a symptom of a failing/leaky EGR cooler. Might want to check around there.2014 F30 328d twin Turbo. First cold snap (50F) in FL this morning so I used my heater first time today. Don***8217;t use too much in Florida. After driving 20 mins engine heated to normal range when i stopped at red light there was white steam coming from under hood. I thought maybe it was just the heat of engine with the cold weather. When i got to work and i stopped popped the hood and noticed the same steam white smoke coming from under the engine but could not tell where it was coming from. I also noticed my expansion tank was below min range. I let the car cool then purchased some 50/50 coolant Zerexg-05 and topped off the expansion tank. Drove a few blocks to pick up lunch and when i checked the expansion tank the level was down again but i didnt notice the same steam smoke coming from under the hood. Car never overheated and i never got any error codes. But to be safe i parked the car and didnt drive again. Had car towed to the repair shop but they cant get to check it out for a few days from today. I didnt see any puddles under the car and couldnt see any apparent leaks. Engine never went past the mid mark of gauge and no error codes. Just wondering if any advice on what to expect as far as root cause and repairs. Been search the posts but nothing under the 3 series diesel 4cyl with twin turbo. Thanks folks for any advice or recommendations. Cheers!
Sent from my iPad using Bimmerfest mobile app
Hey i was Wondering if you did the tranny flush yet? Im curious what the price will be for that. I know it is never 100% flush due to the fluid that remains inside the internal parts. Thanks.Great thread!
I switched from an old e39 (2001) to a 2014 328d (45k miles) in January AND just moved to Orlando 2 weeks ago! Let's stay in touch on mechanics and service centers in the area. I'm located in the SE corner (Lake Nona).
One item that I found so far is that because I have the Msport option, some of my parts are unique to my car only. Found out the hard way when a rock went through my AC condenser and the only part I could find was from the dealer at $650.
The diesel X-drive models dominate and there seem to be very few 328d RWD models out there on the road. Parts are fairly hard to find, so check around different sites if you need minor parts (like underbody plastic panels).
So far the car has been fairly good with great mileage. And luckily diesel is cheaper here than in the Midwest.
Thanks to everyone for posting all the different issues to look for. I'm approaching 60k miles now (I bought the diesel in Ohio because I had a long commute) and need to look into brakes, filters, and a possible transmission flush.
So verdict is in. Indy shop tells me that the thermostat housing has cracked at the upper feeder tube and is leaking. What i dont understand is no error codes flashed and the car didn't seem to overheat nor did the oil temp go beyond normal range. BTW bill is going to be $1200 to replace the feeder tube and thermostat and housing and gaskets. Seems like a ton of money for parts that cost less than $150. Any techs out there feel like this job is really over 5 hours of labor?High coolant useage has been a symptom of a failing/leaky EGR cooler. Might want to check around there.
