2014 535d xdrive battery got very low and has chassis, steering, brake, restraint, abs, engine light.
7.7K views 17 replies 6 participants last post by  bambam_320
#1 ·
Hey everyone!
I'm having an issue with a US spec 2014 535d xdrive, 88k miles, because I let the battery get too low. I was able to start it, took a solid 30 minute drive, then after about 10 minutes started it again and received all of these codes. I was told it may be in limp mode but im not sure what that is exactly. I've since charged the battery, the sitting voltage with engine off and charger removed is 12.6V. I've tried clearing the codes but they are all pending. I've tried disconnecting and reconnecting the battery to no avail. I've tried turning the steering wheel, lock to lock, then shutting off and restarting and vice versa. The car is hard to steer, the parking brake hard is to release.
The battery drain came from a drivers side rear door comfort access handle. I never got around to fixing it because I forgot about it.
The following codes are available through a Foxwell NT520-Pro:
U0126 OBD-||: Lost Communication with Steering Angle Sensor (SAS) Module
U010E OBD-||: Lost communication With Reductant Control Module
P203E OBD-||: Reductant Level Sensor Circuit Intermittent/Erratic
P0500 OBD-||: Vehicle Speed Sensor A
(For about a second after engine start, the speedometer displays 0, then --- persistently)
U0416 OBD-||: Invalid Data Received From Vehicle Dynamics Control Module
After reading through some of the information on these, they all have a root cause of loss of power and/or intermittent power. I'm hoping there are some ways of restarting the engine controller module and all the other modules as well. Like a hard reset, maybe? Do I need something more appropriate to clear the codes? Am I looking at replacing some of these modules?
Thanks for reading! I'm grateful for any advice!
#9 ·
I tried clearing the OBD codes from a foxwell scanner but they never cleared in the car, even after a battery disconnect, the codes remained set. I'm not sure if I have a bad scanner or one that will never work in this situation. Could you recommend one, please?
#8 ·
I've been looking at some but wasn't sure if a new battery would work. I'm not sure about the procedure and registering a battery. I only have a small OBD scanner that doesn't work well for BMW's. Is there a better program or diagnostic tool I could use for that? Would I need to clear the codes after installing the new battery? Do you know where I could get a procedure for the battery replacement? Thanks for the info!
#12 ·
I got another reading from the car after changing the battery... Haven't registered the battery yet but will do that soon, I borrowed my friends scanner which doesn't allow for registering a battery.
Connection profile: BMW OBD-II / EOBD F-series
OBD-IIOBD-II
DTCs: 5
U0416 [0xC416]
Invalid data received - vehicle dynamics control module
Status: Pending
U1126 [0xD126]
Status: Pending
U010E [0xC10E]
Reductant control module - communication signal lost
Status: Pending
P203E [0x203E]
Reductant level sensor - circuit intermittent/erratic
Status: Pending
P0500 [0x0500] Archive (inactive)
Vehicle speed sensor (VSS) - circuit malfunction
Vehicle Speed Sensor "A"
Status: Permanent
Engine control unitEngine control unit
DTCs: 9
CD9518 [0xCD9518]
Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear
CD943F [0xCD943F]
CD9456 [0xCD9456]
CD9451 [0xCD9451]
CD9409 [0xCD9409]
CD94C1 [0xCD94C1]
CD94A8 [0xCD94A8]
CD9526 [0xCD9526]
CD94CF [0xCD94CF]
Transmission control unitTransmission control unit
DTCs: 4
CF1601 [0xCF1601]
CF16C1 [0xCF16C1]
Status: Test failed, Test failed (current drive cycle), Pending, Test failed since last DTC clear
CF16D1 [0xCF16D1]
CF2FC2 [0xCF2FC2]
Engine control unit #2Engine control unit #2
DTCs: 6
CBD429 [0xCBD429]
CBD433 [0xCBD433]
CBD434 [0xCBD434]
CBD431 [0xCBD431]
CBD432 [0xCBD432]
805256 [0x805256]
SRS/AirbagSRS/Airbag
DTCs: 1
C9542D [0xC9542D]
Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear, Warning indicator requested
IPDM/Junction box (JBBF)
No DTC found.
Steering column
No DTC found.
All-round vision cameraAll-round vision camera
DTCs: 1
CAAC02 [0xCAAC02]
Center safety unit
No DTC found.
CAN gatewayCAN gateway
DTCs: 1
801C20 [0x801C20]
Fuel pump
No DTC found.
Transmission/4WD
No DTC found.
Suspension/Dynamic managementSuspension/Dynamic management
DTCs: 10
D017B7 [0xD017B7]
D017AB [0xD017AB]
D0179F [0xD0179F]
D017C1 [0xD017C1]
D0153D [0xD0153D]
D01782 [0xD01782]
D01B3A [0xD01B3A]
D015BC [0xD015BC]
D02D2B [0xD02D2B]
D01A1B [0xD01A1B]
TPMS
No DTC found.
Parking brakeParking brake
DTCs: 5
480513 [0x480513]
D394BE [0xD394BE]
D39A3E [0xD39A3E]
D395BC [0xD395BC]
D39B68 [0xD39B68]
Treble bass extender
No DTC found.
Heads-up display
No DTC found.
Car access systemCar access system
DTCs: 1
D91420 [0xD91420]
Alarm
No DTC found.
Right headlight
No DTC found.
Center roof module
No DTC found.
Gear selector switch
No DTC found.
Dashboard/Instruments clusterDashboard/Instruments cluster
DTCs: 4
E12C11 [0xE12C11]
Status: Test failed, Pending, Confirmed
E11490 [0xE11490]
E12C1F [0xE12C1F]
E1146F [0xE1146F]
Flexible bus interface
No DTC found.
Infotainment system
No DTC found.
Parking sensorsParking sensors
DTCs: 3
E21700 [0xE21700]
E21703 [0xE21703]
E2170D [0xE2170D]
Central electronics
No DTC found.
Tailgate/Rear hatch
No DTC found.
Driver's seat
No DTC found.
Front passenger seat
No DTC found.
Central module (in driver's footwell) (FRM)Central module (in driver's footwell) (FRM)
DTCs: 4
E58500 [0xE58500]
E58507 [0xE58507]
800FF9 [0x800FF9]
E58D62 [0xE58D62]
Climate/heater/Air conditioning
No DTC found.
#13 ·
I finally got the carly scanner, registered the battery and cleared the codes. Then I received about 105 codes. Cleared them again and read 71 codes this time. After repeating, I always receive 71 codes at the minimum.
It seems that they all have to do with the DSC, ICM, no wheel speed info provided anywhere. The codes are all coming right back. I'm wondering if my best bet is a bad fuse or getting the ISTA and resetting the modules individually. There are a few INFO codes that mention fault memory is fully used up and can't be cleared. If there is no response from the CAN controllers then the codes can't be cleared from carly, does that make sense?
Any advice would be greatly appreciated. Thanks !
module responsible​
Message​
Engine​
CD9518​
Transmitter Dynamic Stability control module​
No response​
CD943F​
No message (speed sensor, 46.1.2) receiver DDE​
CD9409​
Message (actual braking torque, 43.3.4) missing, receiver DDE​
CD9456​
No message (status of DSC stabilisation, 47.1.2), receiver DDE​
CD9451​
Signal (vehicle speed, 55.3.4) invalid​
CD94C1​
CD94A8​
No message (request, wheel torque, drivetrain, sum, stabilisation, 43.1.4), receiver DDE​
CD9526​
No message (vehicle standstill status, 263.1.4), receiver DDE​
CD94CF​
Information driving speed, signal: Not plausible​
Central Gateway​
801C20​
Central gateway Module​
ZGM: central fault memory full - no control-unit fault​
Electronic Parking Brake​
D39B68​
No message (brake temperature, 0x37E), receiver EMF​
480513​
Electromechanical brake sensor​
EMF: Wheel speed signal invalid​
D394BE​
ICM​
D39A3E​
ICM​
D395BC​
No message (status, stabilisation, DSC, 173), receiver EMF​
INFO 48058B​
Diagnostic master - queue full​
Airbag​
C95423​
ICM interface (steering angle, front axle, effective, 0x302): Signal invalid​
C9542D​
ICM​
Signal invalid (driving speed, 0x19F)​
INFO 010002​
Error could not be sent on the maximum number of attempts​
Transmission​
CF5406​
No message (speed, wheel, 46.0.1), receiver VTG​
CF5401​
No message (setpoint torque, 43.1.4), receiver VTG​
CF5480​
Interface DSC (setpoint-value input, torque, 43.1.4): signal invalid​
CF5493​
ICM​
Signal (vehicle speed, 55.3.4) invalid, transmitter ICM​
Gear Lever​
INFO 5EAC0A​
Backup interface ICM (speed vehicle): signal invalid​
Instrument Cluster​
E12C11​
Transmitter Dynamic Stability control module / ICM​
Signal (driving speed, 0x1A1) invalid, transmitter ICM / DSC​
E11490​
No message (display, Check Control bypass, 0x36E), receiver KOMBI​
E12C1F​
Signal (vehicle distance covered, 0x2BB) invalid​
E1146F​
No message (status, stabilisation of Dynamic Stability Control, 0x173), receiver KOMBI​
E114DB​
Instrument panel: Message for condition-based service: Message from CBS user (BBV) has failed​
E114DC​
Instrument panel: Message for condition-based service: Message from CBS user (BBH) has failed​
INFO 930004​
Diagnostic master client: overflowed data clipboard in active response handler​
Air Conditioning​
E71432​
ICM interface (vehicle speed, 0x1A1): Signal invalid​
Car access system​
D91420​
ICM CAN message vehicle speed: failure or invalid content signal (V VEH COG, ST V VEH NSS, alive qualifier, CRC)​
Park distance control​
E21700​
Signal (vehicle speed, 0x1A1) invalid​
E2170D​
E21703​
Interface ICM (distance travelled, vehicle, 0x2BB): signal invalid​
Top Rear Sideview Camera​
CAAC02​
Signal (vehicle speed, 0x1A1) invalid, transmitter ICM​
Foot well module​
E58500​
Message (stabilisation of Dynamic Stability Control, 0x173) missing, footwell module receiver,​
E58507​
Integrated Chassis Management
transmitter interface (vehicle speed,
800FF9​
Evaluation electronics, contact-free tailgate opening: Parameterisation faulty​
E58D62​
Evaluation electronics, contact-free tailgate opening: Local interconnect network bus, communication fault​
Integrated Chassis Module​
INFO 420006​
Reset​
Selective Catalytic Reduction​
CBD429​
No message (wheel speed, 0x254), receiver SCR​
CBD433​
Signal (rear left wheel speed, 0x254) invalid​
CBD434​
Signal (rear right wheel speed, 0x254) invalid​
CBD431​
Signal (front left wheel speed, 0x254) invalid​
CBD432​
Signal (front right wheel speed, 0x254) invalid​
805256​
Active tank SCR fluid level sensor: Echo recognised as faulty​
Satellite Module Center​
CC94BE​
Anti Theft Alarm System​
INFO 410006​
Reset​
Telematics​
INFO E14431​
Invalid signal in CAN message v veh​
INFO E14413​
Timeout CAN message stat gang backwards​
INFO E14414​
Timeout CAN message stat zv klappen​
#18 ·
Yes, that fuse is responsible for the door handles and the DSC, all of those codes are coming from the DSC. When its on and running, it will turn every other computer in the car back on and most if not all of those codes will go away. My problem handle was drivers rear but yours may be different.
