1 - 9 of 9 Posts
2015 528i
Not sure why brake would squeal with sharp sound when reversing and turning, anybody knows why? :cry: Thanks in advance for your help. It's a 2016 535i MSport with 24000miles.
Not sure but don't think it is anything big. I will check pads first to see how it is wearing. First time I heard anything like it from 2016 535i.
Munich Mark - 2014 535XD
Object between sheet metal cover and disc ? Makes a terrible shreeking sound ?
2015 528i
Discussion Starter #5
Yes, makes a terrible shrieking sound, I think it's the front wheel(s), only when I turn and reverse.
Sheet Metal rubbing against Rotor, just bend it slightly per hand or check for a stone or object... Sometimes only does it in Reverse, resonance effect.
2015 528i
Discussion Starter #7
Thx, dumb question, covered by warranty? If not, which I expect, how much should that cost me to get it checked out and fixed or cleaned. Thanks.
Premium Member
Squeeky brake as you describe --- I would have it to the dealer as soon as is convenient to me. 2016, unless you have over 50,000, would be under warranty and if the squeeky brake is a new sound, then take it in. As least it is in your records for any future issues.
Warranty ? maybe, I just put down a Mat, grabbed a long screwdriver and moved the flexible sheet metal plate behind the Rotor 1mm farther away... so simple, not worth the time to make a service appointment at least for me.
1 - 9 of 9 Posts
