1 - 2 of 2 Posts
Hi All, I had a check engine light come on and had the dealer run the code. They found that there was a vacuum code showing. They did some investigating and found that a rat/mouse had chewed on the electrical wire located in the passenger rear wheel well. I don't have any more information other than the dealer wanting $800 to fix it. They didn't state if they were going to cut the wire and solder in a new connection or just replace the entire electrical cable. Can anyone point me to where I can buy that cable? Does anyone know a part number? I tried finding the estimate from the dealer to see if it included any part numbers but it did not. I'd also like to add that it was my assumption that a vacuum line wasn't electrical but an actual hose... apparently I was wrong. I saw a video that the tech took from the rear passenger wheel well that clearly showed frayed wires and they kept referring to it as a vacuum line of some sort.
Hoping someone in this forum can point me in the right direction!
1 - 2 of 2 Posts
