Hello, I've been trying to diagnose a very subtle and sporadic clicking noise coming from the flywheel inspection window at idle, when i decided to pry at the flywheel with a bar and saw the amount of play it had. First of all, the tooth ring seems to be slightly loose, as the car starts normally, but when i pry at it, it bends as seen in the video, pretty sure that shouldn't be normal, but it isn't my main concern. My main concern is the amount of play in the flexplate+torque converter assembly when i pry at it, and i'd love to hear from someone whether that amount is normal. Flexplate is not cracked, all bolts (flexplate bolts and TC bolts) are tight.
