1 - 12 of 12 Posts
Looking for a project car
Is this good or bad?
Investigative Tinkerer
It means you're getting some serious bite on that left front (outside) wheel. Can you do that in both directions?
Nice picture!
Discussion Starter · #3 ·
Nice picture!
I don't know if I could get the driver side front off the ground with my fat butt in the driver seat!
Nice pic!
Stock swaybar and end links up front? Sort of looks like it's lifting before I'd expect the stock swaybar to pick it up. Not a problem if you're not understeering, I'm just curious.
Discussion Starter · #6 ·
dwm said:
Nice pic!
No and no. I have a RD front sway bar with RD adjustable endlinks attached to the control arm, not the strut. No understeer at all. That was a very fast right hand sweeper that I was running at full thorttle. :)
BobC said:
details and pics please, I just put the RD bars on my car a couple days ago.
I am hoping to get my TC Kline D/A setup to do that this weekend. It wil be my first time out with the new suspension.
Discussion Starter · #8 ·
I don't have any pictures but, I used the RD adjustable endlinks that are designed to be used on a rear sway bar. They are a little less than half the length of a stock front sway bar link. I got them from TC Kline, I don't remember what the price was. On top of those you'll need the U shaped bracket, nut, and washer from a non-M E36 car to create the mounting points on the front control arms. I got those parts from my local dealer for a few dollars.
Hope this helps.
Hope this helps.
any particular advantages of runnin the links from the control arm as opposed to the strut
Discussion Starter · #10 ·
There are two advantages:
First, the angle between the sway bar and the end link is closer to a right angle when conecting to the control arm.
Second, the adjustable rear end links are about half the price of the adjustable front endlinks :)
Hope this helps.
I don't wanna burben you too bad, but do you know of any part numbers I need or is there a DIY write-up somewhere so I can do this?
Discussion Starter · #12 ·
I don't have the part numbers handy but I'm sure I could look them up when I get home.
1 - 12 of 12 Posts
