1 - 1 of 1 Posts
I have a fault on my passenger window the problem is that it inches up and down so i have to continually press the switch for it to work. i have fitted a new window regulator and the fault is still present. i have noticed that when the window is about half way up it inches up when you close the door . On the drivers door this only happens when the window is in the top position. the motor is ok i have checked the commutator and it is clean. My question is are there any sensors inside the door that detects position of the window.
many thanks
grant
1 - 1 of 1 Posts
