It can be done, but not as easily as you think or as some make it sound. Search around, you will find conflicting reports of what it takes. Some say it was plug and play, but some say it isn't. There is no way it could be plug and play though, the DME's are different for one, the 330 has bigger injectors and a different MAF. At a minimum you would have to figure all that out. Then there is the issue of your trans not being rated for the increased HP and Torque of the 3.0 motor. You'd be better off finding a 328 motor and dropping that in. You'll get 20-25 extra HP and it IS plug and play for that one.
