I've got a 2001 325i with the 5-speed manual transmission. Ever since the day I got it I've experienced a very uncomfortable shudder in the transmission when downshifting. It only happens when I downshift at low rpms without rev-matching with the throttle.
It's most noticeable when I'm slowing down for a turn in local driving. Say I'm in third gear and gently slowing down to make a right turn at around 15mph. When the rpms drop to about 1200 I take it out of third and put it into second. As I gently let off the clutch in second, right at the point where it engages, the entire car shudders and makes a really low booming sound. The entire car vibrates for about 1/2 a second and then it goes away. I can make the shudder last a little longer if I let off the clutch slower, but I can never make this transition without the shudder.
I took the car in to the dealer and they took it for a test drive. The tech said that he didn't notice anything out of the ordinary. He then went on to tell me that BMW's have a spring-loaded flywheel and that they were designed to "give" a little when shifting to smooth out the transitions.
Is this normal? Do other E46 325i's shift this way too? I've never driven another one so I don't know.
Please help!
Please help!
