1 - 3 of 3 Posts
Super Moderator
Hi and welcome to Bimmerfest :wave:.
The guys in this forum will be able to help you out with any problems :thumbup:.
Discussion Starter #3
I got the triangle with the exclamation point and a circle with an arrow, also had the ABS light on. I replaced all the brake pads and all sensor cables. I checked the reluctor rings as I read they can rust and swell causing probs. Rings are fine, no corrosion. STILL have triangle - exclamation point with the arrow. I've reset error codes, still have error light. Besides the brakes and reluctor rings I have no idea what my issue is. Any help would be greatly appreciated.
1 - 3 of 3 Posts
