Good morning everyone,
I have a 3335d which I brought about 6 months back. Had to get some recall stuff done so left it with dealership yesterday and got 328 loaner.
After driving 328 I felt 335d is heavy on steering and sluggish in pedal response. Somehow 328 feels much lighter to drive and better in throttle response. Did any of you had similar issues? I am worried that something may be wrong with my car as it should not be the case for 335's.
Assuming you drove an e90 328, NO! I thought the 328 was a pig and I couldn't wait to get back in my 335d. If you want to improve steering response buy some better wheels and or tires.
RFT's are really a problem. Ride is not very good with them. 328 I got is from 2011 so must be older version/model.
I dont think for 3 liter engine, 200lb should make a difference at low speed. It may change 0-60 time but not whole experience. I will check which tires loaner has but if that is causing difference then shame on BMW on putting RFT's.
If it was a new F30 328i, it has the EPS and just feels that way. If the 328i was non-sport and your 'd has sport package it would feel that way. Even if not, the 328i is about 200 lbs lighter than the 'd.
@OP, are you referring to E90 328i or F30 328i?
Its E90.
Sent from my cm_tenderloin using Bimmer App
That shall not be the case. I am unaware that BMW uses EPS on E90 328i, will someone chip in on this?
The steering feel can be light or heavy, however the numbness on the newer EPS is a major disappointment. When BMW released the F10 M5 & F12/13 M6, they ditched the newer EPS unit (on current F30 & F10) & went back to HPS. M division realizes the savings on fuel is so insignificant & most m-car owners are enthusiasts , thus it is not worth to equip M cars with EPS.
The steering feel on 335d is great and very communicative. You can actually tell which wheel is running over uneven surface or pushing the limit. This isn't something that newer F30's EPS can easily accomplished.
It's mystery to me why experience was so different between two cars. May be its because of tires as E90 had normal radials where as mine has RFT's which means I should throw away RFT's soon![]()
I concur. BMW removed the spare tire from the equation and stuck owners with less than desirable RFT's. Changing out my RFT's was the first and best change I made with my car.
If the loaner had the same make RFT's as you, you might want to double check your tire pressure. If they are under inflated that will contribute to sloppiness in the steering fee.
