1 - 3 of 3 Posts
I am doing the DIY Valve Cover Gasket replacement on my 2007 335i and I am having some issues getting all the bolts off the valve cover.
Is there a trick to getting them off? If I apply too much pressure the socket ill slip off. What size socket should I use? I believe I am using an 8MM.
Banned
Are they Torx heads? For which you need a Torx socket?
Remember! Torque spec is 7-7.4 ft lb
1 - 3 of 3 Posts
