1 - 1 of 1 Posts
I changed my t stat had to remove intercooler and radiator fan to help do room for t start removal.
Now I'm at the point of putting fan and intercooler back.
I installed the intercooler 1st since the fan slides into it to hold it in place at the bottom.
Problem is because the ic chargepipe is there I can't move the black coolant line that runs in front of the belt from driver to passenger out of the way. I can't see also how it's going to clear for the intercooler lower charge pipe rubber mount.
Anyone experienced this? How do you get it back? I'm not sure but it seems this coolant line is only there on the IS models since DIYs don't show it... I also have the 6spd so no tranmission cooler.
I'm a bit lost now.
1 - 1 of 1 Posts
