Gear ratio's
Again my feeble lack of communication rears its head
And then to cosider that I wrote some fancy Dyno prigrams to enable you to choose your gear ratio's- I should retire :tsk:
Just to summarise my thoughts, originating in the days of running Hewland boxes.
You have a gear ratio in each gear of your gearbox with the final drive usually being overdiven anything from 15 to 27 %.
Then you have your diff ratio, that is numerically lower as your engine torque increases.
Most people only have access to different differential ratio's, whilst we should strive to be able to change the internals of the gearbox to give us the most suitable powerband :bigpimp:
The easiest way is to chuck the motor on a Dyno and see where it makes power in the Rpm band & then choose the gears accordingly.
I normally choose 1'st so that I need not slip my clutch (in the old days of open wheel racing a severe offence) and then go up in the range so that I never fall out of the power band.
The final gearbox ratio being determined by what top-speed I need to attain.
I see a lot of BMW's ran Borg Warner & Getrag boxes, so getting different internals should not be too difficult :thumbup:
