Hi, i am currently doing research for a project i would like to build, and i want to ensure i have made a good choice with using the 4.4i X5 as a donor for its drivetrain from the diff to the hub and the suspension.
first, can the diff and axles handle 500Whp/600 W lb ft? i plan on using an OM606 diesel and i do not want to use a diff or axles i will regularly break.
and what is the smallest wheel that can be fitted that clears the brakes?
thank you for your time
Keith
Keith
