New thread, in case any other X5 xDrive40e owners care to post/debate best practices that differ from fossil-fuel X5 variants.
OF COURSE, you can drive the 40e just like any other X5, so let's stipulate that option right up front.
But, if so inclined, you can drive it a little more "hybridishly."
Just to get the ball rolling, then:
Having driven the Mt. Washington Auto Road in a hybrid, I recall that they hand you a special sheet of paper with hybrid-only best practices for the 40-minute descent. If you ride the brake in a normal car, you're likely to overheat the brakes, and possibly lose control on the way down. People have indeed been hurt and killed due to brake failure. So you have to come down in first gear, and some cars pull over to cool the rotors and pads. Police cars aren't allowed, because they often have first gear locked out. But in a hybrid, it's the opposite. You're actually encouraged to ride the "brake" (generator, really), because it just dumps into the battery. They also tell you to put the windows down and blast the heater out the window, because it turns your car into a big 'ol hair dryer, which acts as the sink for excess electricity regenerated on the way down.
Any other tips?
- Accelerate modestly in normal daily driving, unless you desire to accelerate rapidly (i.e., you want to pull away quickly). This is similar to using the "disable start/stop" button on a typical X5. In other words, don't floor it at every single red light (...but, hey, maybe blow past a Volt once in a while
- Above ~1 MPH (?), light braking is regenerative, and regeneration is your friend. Unless you're being intentionally sporty (as above), look further down the road than you might otherwise, and "drag" the brake a long way when approaching red lights. Normally, we're all taught not to drag the brakes. Here, dragging is preferred. Hard braking uses the calipers hard, which just makes heat. Of course: brake as hard as the situation requires, for safety or sport.
- Both the departure time feature and the BMW smart phone app will use "shore power" to run A/C or heat electrically. So get in the habit of asking for remote climate control 10 minutes before you intend to unplug and drive. This increases range, fuel economy, and comfort.
- In very heavy stop/go, low-speed rush hour traffic, consider using "Max eDrive" "Eco Pro" and ACC (if equipped) together, with the ACC set at 20 MPH, its minimum. This has the effect of electric-only automatic follow, and is waaaay awesome! Much of your accordion-traffic-braking will be regenerative. Note: YOU MUST STILL PAY ATTENTION!
- Regeneration is a function of wheel speed over land, not tach RPMs. In other words, downshifting the (actual geared) transmission and rev'ing higher doesn't get you more regeneration. So drive normally if you want to recharge the battery (wasting more fuel) except in "Max eDrive" mode. Hitting the "Save Battery" mode gets you the most regeneration, even under light acceleration.
- Rock crawling uphill seems smoother with >10% battery. Plan ahead if you're driving to the hills/lake/camp/rocks. Keep a little juice in the battery.
- Plug in whenever the opportunity presents. It's almost always cheaper, and the car is more fun to drive with a full battery than a dead one. Oh, and the EV spots tend to be fantastic! First ones after handicapped, usually. :thumbup:
Any other tips?
