1 - 2 of 2 Posts
Jayhawk
I have an opportunity to buy a used set of four 8.5 inche SSR Comps for track use. They have a +44 offset. Will I need to use 5mm spacers? I know that the e36 and e46 cars use the same wheels. The seller has an e36 M3 and uses 5mm spacers to run 255's PSC's.
Are there any issues using spacers at the track? Just curious to hear opinions.
TIA
Living on the redline
the offsets on the E46 are larger than the E36, those numbers should be fine without spacers, though maybe depending on the tire size
1 - 2 of 2 Posts
