Which BMW site are you referring to? As for tires, you can go from high dollar RFT's to lower cost non-RFT's. From what I have read & experienced, I will go to the standard Non-RTF's on our '15 X5 when current tires need replacing.yes. This is so pretty but the tires are like $500 each....
Wonder why they dont have it anymore on BMW site.
You maybe right. I just found it in tirerack. This is 20 inches, for 21 inches I enclosed below which at least around $400. Original x5 uses 18 inches wheels which about $250 to $350Which BMW site are you referring to? As for tires, you can go from high dollar RFT's to lower cost non-RFT's. From what I have read & experienced, I will go to the standard Non-RTF's on our '15 X5 when current tires need replacing.
Not sure what size tires you are referring to for the $500 each. The owners manual calls out
Front: 285/35 R 21; Rear: 325/30 R 21 for the 21" staggered wheels. 21" does limit what tires are available & price is higher. Non-RFT's do run a little cheaper.
By bad akii.......Not sure why I was thinking 21". Maybe from another post.You maybe right. I just found it in tirerack. This is 20 inches, for 21 inches I enclosed below which at least around $400. Original x5 uses 18 inches wheels which about $250 to $350
https://www.tirerack.com/tires/Tire...arRatio=35&rearDiameter=20&rearSortCode=60205
https://www.tirerack.com/tires/Tire...arRatio=30&rearDiameter=21&rearSortCode=61047
