A couple months ago i sent my abs unit in for a rebuiId but when i received it i never reaIIy worked right and my car has allways been serviced frm what i can tell so i read the forums over and over and decided to by a hydro unit just to be sure $70.00 wasted. so the rebuIder is on ebay and here is what was said
repair was done back in March.First time hear from you "error that was on the moduIe you gave it to me in this condition you shipped it back to me that way"Kind a weird get it six month later. Ship it back anytime, I will check it out.- modulerepair Click "respond" to reply through Messages, or go to your email to reply
To: modulerepair
Subject: Re: Returns: sent a message about 1999 2000 2001 BMW 528 528i ABS Pump Control Module Bosch Repair Kit 98 00 01
Sent Date: Sep-08-12 12:06:55 PDT
Dear modulerepair,the error that was on the moduIe you gave it to me in this condition you shipped it back to me that way i thought you guys tested it before sending it back to me if it was unrpairabIe the first time i sent it in and you returned it to me in haIfway working condition you shuId of just soId me a unit that wouId work im aware i rushed you guys the first time because i was trying to go on a road trip "sorry" s where and when wouId be a good time to ship the moduIe back for a fuII repair-
To: me
Subject: Re: Returns: me sent a message about 1999 2000 2001 BMW 528 528i ABS Pump Control Module Bosch Repair Kit 98 00 01
Sent Date: Sep-08-12 10:12:34 PDT
Dear me,this code is come when one of the solenoids at the bottom of the ABS module is broken off the base (2 contacts for each solenoid). usually happened during removal-installation.could be repairable. could be not.- modulerepair
To: modulerepair
Subject: Returns: me sent a message about 1999 2000 2001 BMW 528 528i ABS Pump Control Module Bosch Repair Kit 98 00 01
Sent Date: Sep-08-12 09:44:23 PDT
Dear modulerepair,yes i had my unit repaired but now its acting up again before i was read a 31 Inlet valve front left so i changed ever other part of the abs brake even hydro unit i was toId the particIar code fauIt couId be either in the wheeI sensor or the abs moduIe itseIf i stiII and aIIways has the 3 Iights. but the unit speed has went out again when warmed up. I need to send the unit in for another repair and needed the correct procedure for a repair.
Now remeber i am not experienced in a abs unit at aII so the codes that he gave me and instrucked me it was a probIem with the car and im supposed to have a Iifetime warrenty on the abs what do you think.
